Disabling Multi-Threading IP block
I'm trying to generate support files for an IP Integration Node and I always get this error:
FATAL_ERROR:Simulator:Fuse.cpp:209:1.129
Then I would try disabling the Multi-Threading in the compiler, is that possible?
If yes, how?
Thank you in advance.
(3,403 Views)
Hello Ste88,
As far as I know you cannot change those compiler options from inside the LabVIEW environment. (I could be wrong, but I haven't seen an option to do this from the standard IDE)
The error could also be sourcing from some of the following topics:
http://www.xilinx.com/support/answers/32357.htm
Can you share code that would allow me to reproduce this issue at my side?
If I can reproduce it,  then I can also do further troubleshooting and (if needed) escalate it internally.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,232 Views)
Hello ThiCop,
thank you for your reply, I have already checked that page and my intention to disable multi-threading comes from there.
I'm trying to integrate some .vhd files generated by Moby-Dic toolbox in Matlab, they correspond to an explicit ModelPredictiveControl.
Maybe there is a batch file somewhere, but I still don't know where to put the option for the compiler.
At the moment I "solved" reducing the prediction horizon of the MPC and thus the complexity of the problem, but also the performance.
(3,206 Views)
