Odd even number and Boolean indicator
Hi all,
For example, I have these numbers from 0 to 112233. It will start counting from 0 and shown it on an output indicator. When it is even number (0,2 or 4,...) the Boolean indicator will become false, but when it is odd number (1,3 or,...) the Boolean indicator will become true.
I'd like to ask if it is possible to detect the values changing in output indicator when it start counting numbers from 0, and then the Boolean indicator will become false or true depending on even or odd number shown on an output indicator? How can I do that?
Thank you!
Message 1 of 17
(12,082 Views)
Tip: Use "modulo" (called Quotient and reminder in LV) by 2 and compare to 0 or 1 (regarding even or odd).
Norbert
Norbert
Expert: Geometry
Message 2 of 17
(12,078 Views)
Most logic primitives will work with integers. AND with 1 then compare with zero.
Lynn
Message 3 of 17
(12,062 Views)
A bit like this Smiley Wink
Message 4 of 17
(12,061 Views)
AND with 1 is way more effecient than the Quotient & Remainder to divide by 2.  I recommend following Lynn's example.
Message 5 of 17
(12,051 Views)
It may not be that much faster. In the little test VI Q&R takes 581 ms for 10^8 iterations while AND takes 503 ms. That is 78 ps difference. Hardly enough time for a coffee break. Unless you drink really fast.
Lynn
Message 6 of 17
(12,026 Views)
I prefer Norberts answer because he provided a tip to this obvious homework question rather than a full solution. Smiley Sad
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 7 of 17
(12,020 Views)
... so a better tip would have been to explain that for any even integer the lowest bit is zero. 😉
Message 8 of 17
(12,010 Views)
Yes, both are "fast enough" for all practical purpose. Even thought they are nealy identical in speed, the Q&R shows more variability in execution time (10% variability), while the AND is singificantly more stable (>1% variability).
(Make sure you disable debugging for a 10x speedup overall)
It also seems that the AND code folds better. If we change the control to a diagram constant, the AND version speeds up by a factor of two, even though no folding is shown anywhere inside the sequence structure. I have no idea what that means. 😄
Message 9 of 17
(12,000 Views)
I also tried Rotate with Carry. The Carry output gives Odd directly. Its speed is almost identical to Q&R.
Lynn
Message 10 of 17
(11,979 Views)
