Odd even number and Boolean indicator
@johnsold wrote:
I also tried Rotate with Carry.
Me too 😄
Message 11 of 17
(1,539 Views)
I love it when a homework question (d)evolves into something like this.  😄
Jim
Message 12 of 17
(1,524 Views)
We can only hope the OP tunes in and learns something new.
@ Altenbach:  Sooo, the LSB of the binary representation of number is like the result of an isOdd() function.  Smiley Surprised Completely obvious but I never thought of it that way.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 13 of 17
(1,517 Views)
Honestly, i disregarded performance (speed and memory wise) consciously because he might have the task to develop code which does not determine even or odd, but maybe something with more options.
Therefore, the hint to Q&R is imho essential as it is a very powerful, but simple to use option for numeric "evaluations".
Norbert
EDIT: But i do like the discussions about performance and better (advanced) options to squeeze the last bit and byte out of a computer system!
Norbert
Expert: Geometry
Message 14 of 17
(1,494 Views)
@Norbert. I saw your edit and agree. This sort of task certainly tickles the little grey cells.
With that in mind here is another contender ... not quite as fast as the AND, but not too shabby. Smiley Happy
Message 15 of 17
(1,485 Views)
Well, you are taking a 32 bit integer, coverting it to an 8 bit integer, then to a 8x larger (in memory) boolean array, then throwing 7/8 of the information away, retaining only 1/8 of the data. That seems lik a lot of unecessary data manipulation. 😄
(It is possible that the compiler can streamline some of this under the hood, but that does not make it right).
Message 16 of 17
(1,473 Views)
... just trying a few ideas and seeing what LV makes of 'em.
"(It is possible that the compiler can streamline some of this under the hood, but that does not make it right)."
I don't see any broken lines so where is the wrong bit ? Smiley Very Happy
Message 17 of 17
(1,465 Views)
