The output / input configured in the OPC Server is different from the working in the S7-200
I'm taking the first steps in LabView. I´m using LabView to make the graphical interface with a PLC S7 200 CPU226, but I have a problem.
For example when I try to read an input or force an output through LabView the port that I set in OPCServer is not the same as I´m going to read / activate in S7.For example when I force the output Q0.0 in LabView, PLC actives the output Q1.0 or when I try to read input I1.0 in fact I'm reading the I2 .0
Thank you for your cooperation
(2,901 Views)
Hi Guerraf,
Have you find a solution yet? I wasn't able to find anything consistent about this issue. You may want to try this tutorial :
NI-DAQ OPC Server Troubleshooting Wizard: Not All Channels Functioning
Please let us know if it helps at all or if you are still having troubles.
Have a nice day,
M-Junior
(2,652 Views)
Hello Marc
Thanks for your reply.
I was following the tutorial found at this link:
http://forums.ni.com/ni/attachments/ni/170/585958/ 1/opcsiemenss7200.pdf
In the OPC Server to configure the "tags" the procedure said to put boolean and thus never worked, I tried to put as byte and is now running.
Sincerely,
 F Guerra
(2,638 Views)
