Disabling the front panel display
Just want to ask, is there a way LabView exe file when called and run by another software
will no longer show it's front panel.
I tried to explore it on building its executable but target setting remove panel in
vi settings is hide.
First, I don't know if possible that front panel display can be disabled  ?
Second if possible any suggestion how ?
Kabo
(2,867 Views)
Hi Kabo,
you can use the property or the invoke node with "FP-> open".
Hope it helps.
Mike
(2,861 Views)
For every executable at least one Front Panel should be open (may be hidden). I am not sure about DLLs though.
Ton
My LabVIEW Ideas
(2,857 Views)
