offset elimination on csv file
Hello everybody,
i'm not really used to lab view 😞 but i would like to read a csv file with voltage data. this data has a 3V offset.
how can i eliminate the offset.
i tried to substract the offset by placing a minus icon.. but that wasn t working.
it would be great, if someone would have an example file
u all have a great weekend
Greets from germany
Josef
(3,666 Views)
How did you read the csv file, and how did you try to use the "minus sign"? What is the format of your csv file? Is it a single column? E.g.:
(3,661 Views)
Hi smercurio
i added a screenshot    i hope this will help
the csv file is like
"2.495177,2.495177,2.493971,2.493971,2.496383,2.491559,2.496383,2.492765,2.495177,2.491559,2.491559,2.491559,2.492765,2.491559,2.490354"
all in one line.
thank u for ur quick answer!!
Greets josef
(3,651 Views)
Hi aj,
you should change for the "spreadsheet string to array" function in the aquisition part:
-array constant from string type to dbl type
-use a format string of "%.;%f" as you use a German LV with an English data file
-use "," as tab delimiter input
This way you get a DBL array where you easily can do any math (as shown above)!
And please: Never attach downscaled pics of block diagrams - attaching the vi is preferred here... (As a bonus you may get reworked vi with added commentsSmiley Wink)
Message Edited by GerdW on 07-04-2008 06:03 PM
(3,634 Views)
I agree with Gerd,
Attaching the VI would be much better than an image which only shows a section of the code.
R
(3,615 Views)
Josef,
It looks as though you may be subtracting an empty array from your data (in the area of the image marked "Offset"). Remove the constant, empty array and connect a DBL constant with the value = 3.0. The elementary math functions are polymorphic, meaning that they can adapt to various input types. Subtracting a scalar from an array as I described above has the effect of subtracting the scalar from each value in the array and returning an array with the offset removed.
Lynn
(3,591 Views)
Thanks to everybody!!
I did what Lynn said. I connected a DB constant.
Now it is working!
have a great week!
Josef
(3,554 Views)
