Disallow "paste" for an input string
How can I disallow the "paste" function in an input string?
I am using Labview 8.5.1.
Thanks.
Message 1 of 8
(3,930 Views)
Hi tantan,
- disallow shortcut menus for your control
- catch/filter keypress events of Ctrl-V
P.S.: And don't create double posts for the same topic! Keep all information in one place!
Message 2 of 8
(3,923 Views)
Hi GerdW,
Thanks for your feedback. Sorry I can't delete the first post previously before I send out the second post.
For the catch/filter keypress events of Ctrl-V. Can elaborate more about it? Where should I start?
Thanks.
Message 3 of 8
(3,914 Views)
Hi TanTan,
to check keypress events you should (obviously) start with an event structure! 😉
Message 4 of 8
(3,904 Views)
You have to capture the key pressed and discard that if it is a combination of Ctrl and V. Check the attached vi.
Message 5 of 8
(3,903 Views)
Accepted by TanTan
Example converted here:http://forums.ni.com/t5/Version-Conversion/Version-9-to-8-5-1/m-p/2267914#U2267914.
In that thread, I also gave an example without using the keyboard input reference.
Message 6 of 8
(3,873 Views)
Hi Crossrulz,
Thanks for your simple example, it has solved my problem!
Message 7 of 8
(3,831 Views)
I prefer to remove a menu item instead of simply ignoring a seemingly allowed item.
Message 8 of 8
(3,828 Views)
