Disk drive crashed
My hard drive crashed after logging data into CITADEL for about 5 months. It was a 20GB drive that was partitioned into three drives. C; drive was 10 GB and the other two were 5GB each. I had the CITADEL database on one of the 5GB drives. Does anyone have any recommendations for where to put the CITADEL database?? Should it be on the C: drive or on a physically separate drive??
(2,983 Views)
The Citadel database does not need to be logged in a different location other then C:, so the reason why the drive crashed was most likely other then the location where the Database was being logged.
Have you lost all your data ? Did you have a backup of it ?
Regards
Andre Oliveira
(2,983 Views)
I lost some of my data back to my last backup, but not much. I run ghost backups quite often.
(2,983 Views)
