Update Wizard fails due to network restrictions
I wants to test for updates/patches for my installed NI products. I tried the Update Wizard (MAX->Tools->...) by pushing 'Get updates now'.
Then I got the error message: 'Unable to communicate with National Instruments web server -- update check failed.'
Possible reasons for connection errors are certain restrictions at my site: http access is only possible through a proxy, and ftp access is blocked. Configuration options for such circumstances seem to missing - is this true? Any other suggestions?
(3,296 Views)
Ralf,
I'm sorry to hear about the problems that you are having with the Update Wizard. My only suggestion would be to review your Internet Options, and try adjusting some of the settings related to proxy, http, and ftp. I personally have tried adjusting a number of my Internet Options, and I have not been able to reproduce the error that you are seeing. You might also want to talk to your Network Administrator and see if they are able to help.
Regardless of the outcome of that, I would like to assure you that it is easy to find the most recent versions of your National Instruments'(NI) software. In general, NI does not release frequent patches for software, so checking on a daily or weekly basis is probably not a necessity (For example, the last version of
LabVIEW, LabVIEW 6.1, never needed an update). In order to check if you have the most recent versions of LabVIEW, open MAX and expand the Software heading. This will allow you to see the installed versions of all your software. Then you can navigate to the following website, which lists the most recent versions of all of NI's software:
http://digital.ni.com/softlib.nsf/webcategories/9AD71162B755F0E786256BBC005F001A?OpenDocument&node=132060_US
I am hoping that this will help you get going in the right direction.
Jed R.
(3,296 Views)
Hello Jed,
first 'thanks' for your response.
If one has only restricted access to the internet, e.g. only port 80 access through a proxy, the Update Wizard will only work, if it uses http and knows the proxy setting from the IE settings (or you can explicitly set them).
For now I can live with your other suggestion and will
check the link. I should have found it earlier:
http://www.ni.com/support/ -> Product Reference -> Drivers and Updates -> Current Versions
Ralf.
(3,296 Views)
