Display Front Panel using web service(auto refresh image)
I develop a monitoring agriculture program, I want to display my front panel using the web service. What I mean when the VI run, the front panel can be monitor using the url only. I have found example program on this forum and its work. But I try to implement the same method to my program but no image display as the original one. Anyone can help me? I attach the original example program and my program also below.
ORIGINAL PROGRAM = Front Panel Image with Auto Update.zip
MY PROGRAM = Project Monitoring System.zip
ORIGNAL ABLE TO DISPLAY AND AUTO REFRESH THE INDICATOR
my program do not work,
 TO RUN THIS PROGRAM :
- Open 'Front Panel Image with Auto Update.lvproj'
- Right-click on the web service "image publisher" and select 'Start'. This will start the web service in debug mode.
- Open 'main.vi' and run it. You should see the gauge updating.
- In your browser, go to 'http://127.0.0.1:8001/image_publisher/index.html'. You should see the image auto-update every 200ms.
(4,638 Views)
Accepted by topic author nafisnuzrin
The issue comes from the getFPimage.vi in your project. It seems that you disconnected the terminal associated with the Web Service object. This input is required for the webpage to use the command 'get'.
If you copy the getFPimage.vi from the example folder and replace the one in your folder, it should fix the issue (or at least it did for me).
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(4,543 Views)
