Re: Random number generation, odd and even determination etc.
How to generate a random number from 1 to 50 in array
Message 1 of 9
(4,037 Views)
Hi raki,
no need to hijack old threads for your own question!
If you would search this forum you would find a lot of possible solutions as your question comes up quite often! (It's a typical task to let beginners learn LabVIEW features.)
There is a LabVIEW function giving you random numbers with 0 < x < 1 (according to LV2011 help).
from 1 to 50
You need some simple math to scale the number you already got…
in array
Usually you use loops to generate arrays…
Message 2 of 9
(4,026 Views)
Please show the entire homework assignment. A lot of information seems missing.
  • Do you want only integers or real random floating point numbers?
  • In the subject, you talk about odd/even, but you don't mention it in the post.*
  • What does the "etc." in the subject stand for.*
  • To generate a random number, you don't need an array.
  • How many random numbers do you need to generate?
Have you done a forum search? Plenty of solutions have been posted in the past.
* EDIT: I guess you did not write the subject line and it has little to do with your posts. It came from the thread you hijacked before the post got moved.
Message 3 of 9
(4,019 Views)
Hi GerdW
im using a random number function to generate numbers from 0 to 50, but im getting the repeated numbers in a array and as i run it multiple times, numbers gets changed. i wanna know how to remove the repeated numbers in the array. plz can you help me out with this..
Message 4 of 9
(3,913 Views)
Hi raki,
when there is a problem in YOUR VI you need to debug YOUR VI.
Or you attach YOUR VI so we can also debug it…
(I prefer LV2014.)
Message 5 of 9
(3,907 Views)
Im using LV2016....
Message 6 of 9
(3,894 Views)
The simple solution is to create an array of 51 elements (data type does not matter so use a U8 for the smallest memory hit, also use Initialize Array) and then use Riffle.vi.  Use the index array output.  You will now have a random order of numbers from 0 to 50 with no duplicates.  You can use Array Subset if you just need a certain number of values.
Message 7 of 9
(3,888 Views)
sorry... im new to labview can you please help me how to design it
Message 8 of 9
(3,873 Views)
I gave you step-by-step instructions for 2 functions that you need.  If you are unwilling to give it a try, I cannot help you.  Or if you are just lost, go through some of the tutorials.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
Message 9 of 9
(3,869 Views)
