Display/Hide front panel
Hi
I have a labview code that has a MainVI and a SubVI. I need to display/hide the front panel of the SubVI.
I have a case structure which has two cases,
Case 1: I want to display the front panel
Case 2: I want to hide the front panel.
I am currently using the property node, but I cannot which attribute controls the display of the front panel
Please help
(4,061 Views)
A VI is worth a thousand words.
Please attach your VI so we can see what you are doing.
(4,054 Views)
Invoke Node >VI Class>Front panel State is the property.
Kudos are (always) welcome for the good post. 🙂
(4,047 Views)
Accepted by Mr_Miagi
It's Property Node and not Invoke Node. My bad!
(4,041 Views)
Did you see the reply here
(4,037 Views)
