Display Property Node Error 1077
I have created a vi with multiple analog inputs (up to 20), and I want to be able to turn plots on and off on the front panel. I currently have this case structure set up to go through each input (i through N), and the front pannel array (LED buttons) can be turned on and off to choose which plot to display:
Turning the plots on and off work, but I am getting this error message:
Error Message.JPG Error 1077 occurred at Property Node (arg 1) in NetworkAnalyzer_UpdatedDAQmx.vi
Possible reason(s):
LabVIEW:  Invalid property value.
Property Name: Active Plot
Any solutions? Thank you.
(6,531 Views)
Accepted by jaeger10
Are you sure the number of elements in the Boolean array matches the number of plots you actually have? That error implies that you have more elements in your Boolean array than you have plots.
(6,519 Views)
