Display a PDF file in a Window within Labview VI panel
I am generating a PDF by compiling diffrent text files. I want to display it in a Window within Labview VI panel. Please help
Message 1 of 20
(10,209 Views)
Did you mean open a PDF file using LabVIEW? or Bringing a PDF file in front panel?
Message 2 of 20
(10,185 Views)
Accepted by rakesh@labview
You'll need an Acrobat PDF Viewer ActiveX control. Put an ActiveX control on the front panel, then browse to Acrobat viewer to insert it. Then use properties and methods to gain some control over it.
Message 3 of 20
(10,178 Views)
Message 4 of 20
(10,162 Views)
Try to use this attached VI
Please Mark the solution as accepted if your problem is solved and donate kudoes :smileyhappy:
Message 5 of 20
(10,157 Views)
You don't need the open and close as the object always 'lives' in the front panel, but otherwise pretty much like that.
Message 6 of 20
(10,152 Views)
some times its not displaying the pdf. see attached screenshot. ...please help
Message 7 of 20
(10,128 Views)
It's going to be hard to say anything about that problem without the code and the PDF. Is there an error?
Message 8 of 20
(10,119 Views)
Works for me (haven't tested your VI, but it should be just the LoadFile).
Sometimes it takes a while, but eventually it displays. I don't think there's much that can be done about that. The API is primitive.
Message 10 of 20
(10,087 Views)
