Display bitmap image in intensity graph
Hi.
I want to display a bitmap image in intensity graph and I use 'Read Bitmap Image' block and after that 'Unflatten Pixmap' to do that. But the image is up side down and it must be flip verticaly. But I don't know how?
Thanks.
Ali S.Mootab
(2,958 Views)
if the image is transposed (upside down and inverted) just pass your array through the array transpose before you send it to the intensity map, if it is just upsidedown you can do a for loop wnd index each column, reverse the column and rebuild the array.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,952 Views)
