Display gif image from Internet in labview
I want to display a gif image from the Internet and display it in the labview. How can I do this ? for example: http://icons-ak.wxug.com/i/c/k/nt_cloudy.gif
I could not find any vi for gif images in the "Graphics Format Pallet".
(3,147 Views)
Accepted by topic author ManiAm
You can convert the image to another format manually or do a search here for VIs to read GIFs. Here's one example - http://forums.ni.com/t5/LabVIEW/Controlling-Gif-aninimation/m-p/970543?view=by_date_ascending#M43520...
If you also want to download the image using LV, you can use the Datasocket Read function and add "[text]" to the end of the URL. This will return the binary data as a string which you can then write to a file.
___________________
Try to take over the world!
(3,129 Views)
