formatting graph scale to only display integer values
I am trying to simply display a graph that has only integer values and therfore have only integer values display on the scale to alleviate some of the eye congestion on the graph.  ANybody know how to do this fundamental?
(4,305 Views)
Accepted by topic author id
If you wire an integer data type to the graph terminal it should change to integer representation and take care of the problem.
You can also set Digits of Precision in the graph properties to zero.
Lynn
(4,299 Views)
If you are trying to plot in x axis then you need to change x axis display format to integer.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(4,283 Views)
thanks.  My data type is double resulting from the prior calculations and since it was, the graph was not behaving as I remember.  Also, the digits of precision was not the default drop down and I just couldnt seem to find it.  Kudos
(4,268 Views)
