Display message plus stopping VI
Hello!
I am using the "Display Message to user" express-Vi in order to display a message to the user under certain conditions. Is there a integrated way of stopping the VI everytime the message is displayed, or do I have to use a Event Structure?
Greetings
Kristoffer
(3,902 Views)
There is a Stop VI that will halt your application it is in the Application Control VIs and Functions.  If you are in a while loop, you can pass a true to the stop node and a default value of false for all other states.  There is also an Quit Labview VI that will shut down and close the application completely.  I've attached a vi that looks at whether you are running the vi in the development environment or as an executable and stops or shuts it down based on that.  It is Labview 2010.
(3,885 Views)
Accepted by Sjefsgjogleren
Thanks! It was something like that I was looking for!:)
Greetings
Kristoffer
(3,871 Views)
