04-09-2008 01:02 AM
04-09-2008 01:05 AM
Hi ganya,
the description is visible in the content help window, if your mouse hover over this control.
Mike
04-09-2008 01:08 AM
04-09-2008 01:10 AM
Hai ganya,
The Tip is nothing but a small message regarding that control. Whereas Description will give you the exact purpose of it. As mike said when u move ur mouse over that control it will be displayed in the context help(Enable it by pressing ctrl+H).
Mathan
04-09-2008 01:11 AM
04-09-2008 01:12 AM
04-09-2008 01:13 AM
Hi ganya,
did you read my previous post? It is only called "iteration ..." because your control has this name. The message you insert there will be shown in the content help if the mouse is over your control.
Mike
04-09-2008 01:16 AM
Hai ganya,
The above block is user-editable. Even u can give ur own description u want. If u didn't specify anything then appropriate comments will be included defult.
In the figure u attached u used a waveform graph. So by default it will give some description of it.
Mathan
04-09-2008 01:18 AM
