Display only the y-axis label in an XY graph
I want to display on the label on the y-axis but not the scale.
In the properties options, there are only two choices: display scale+label or dispaly scale only. I wish there is a way to display label only.
Is this possible? Or what's the easiest way to put something accurately on the label position?
Thank you for your help in advance.
-Tai
(2,828 Views)
Show the scale with only major tick marks, then color the major tick marks the same as the background. 😄
(There are probably some other ways to do this)
Message Edited by altenbach on 05-09-2006 05:36 PM
(2,825 Views)
This is exactly what i wanted, thank you altenbach!
Tai
(2,813 Views)
