Display real time data on a plot in a sub VI and main VI
I am building a program to measure and plot real time data. Program has several steps so I build few Sub VIs to make it simple. My problem is I am plotting real time data in my SUB VI(it works fine), but in my main program when I try to get the same plot its not real time data plot. Plots appear at the end of the program.  All tips and help would be greatly appreciated. Thanks
I have attached my main VI and Sub VI
Message 1 of 8
(6,168 Views)
Accepted by srms
LabVIEW program is based on DATA FLOW, now, until the subVI will finish execution (while loop will be stopped), the execution in Main VI will not proceed any further.
If you can pass the reference of 'XY Graph' inside the subVI, you'll be able to update the plot (placed on MAIN VI) from within subVI.
Find attached example for your reference.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 8
(6,163 Views)
thanks for the reply. I tried to find some help online. but I dod not know where to start. Can you tell me how do I do that? or send me a link which I can use
Message 3 of 8
(6,147 Views)
WOW that's freekin' magic!
In over a decade of programming LV I have never been able to do anything like this.
Where can I find a good detailed explanition on using References?
=== Engineer Ambiguously ===
Message 4 of 8
(6,143 Views)
You can search of 'Explicit' and 'Implicit' property nodes.
Well here is one link I found for you
Message 5 of 8
(6,136 Views)
Control References: Overview
Message 6 of 8
(6,134 Views)
srms,
You need to mark Moderator's message as the solution to your question.  Not your own thank you message.  First you need to go to the options menu to the upper right of your message to unmark it as the solution.
Message 7 of 8
(6,107 Views)
Its my bad, in my previous reply I included wrong hyperlink, below is the correct one:
Message 8 of 8
(6,066 Views)
