Display string and keep on moving from left to right repeatedly
I want to display three or more string and it should moving from left to right, once all string are displayed it should repeat the same to display string from left to right( for example TV News channel heading news are going bottom of the screen)
VenkatStony
(4,298 Views)
Hi Venkat,
when you want something you have to program it… 😄
This forum will help you on (specific) LabVIEW problems. Do you have them? Can you describe those problems? Can you show them in a VI?
Solution:
Create a string from your "three or more" string parts. Display just a portion of that string in a string indicator. Choose a different portion with each iteration of your display loop.
When you want smooth(er) scrolling: use a PictureIndicator to have pixel-based scrolling…
(4,286 Views)
HI
Yes i understand what you saying. But I need key how to start easy way.
Venkat
(4,279 Views)
this is your key
(4,267 Views)
Sorry if someone has already posted this.  I can't open newer VIs.
aputman
(4,224 Views)
Also in the properties of the string indicator, make sure that "Wrap at Word Breaks" is unchecked.
aputman
(4,221 Views)
