real-time oriented bounding rectangle detection
Hello
I have been traying to write a VI that finds an oriented bounding rectangle (marked at blue in the image) at a certain angle (marked "alpha" in the image)  in each frame of a video.
At first I used "imaq rotate"   to rotate the entire image and the i found an ordinary rectangle but "imaq rotate" taks to long for my application
Any ideas for a differnt algorithm or approach?
thenks
(3,634 Views)
Hi orinoked,
IMAQ Rotate is your best and most accessible function choice for this operation. Digital image processing taks time. If this function does not meet your application requirements, your next choice would be to start implementing your own custom rotation function. Algorithms for this sort of function should be readily available online. Here’s one I found in a quick search: http://homepages.inf.ed.ac.uk/rbf/HIPR2/rotate.htm. However, implementing your own image rotation function would be time consuming and introduce the need for additional code debugging.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,578 Views)
