Display text or number without the indicator border
I would like to display items such as strings, numbers or enumerated types on my GUI without the usual border around the indicator. (ie, I want the string or number to appear on the front panel like a label) Can anyone think of a way to do this?
Chris
Chris Reyerson
Optical Systems Engineer
Arete Associates
Tucson, AZ
Message 1 of 9
(11,898 Views)
Use the coloring tool and select transparent from the upper right corner. Right click with the tool pointed at the border and the background. Use the space bar to select the portion that gets the color applied.
Message 2 of 9
(11,891 Views)
Thanks for the reply, but I cannot get that to work. As far as I can tell, Labview will not allow me to change the color of the border.
Chris
Chris Reyerson
Arete Associates
Tucson, AZ
Message 3 of 9
(11,893 Views)
Right click on the top slanted border line with the coloring tool. When the coloring box pops up, use the space bar to get the left hand color box highlighted by the white box. Then select transparent in the upper right corner. This is in 7.0 format. What version are you using??
http://zone.ni.com/reference/en-XX/help/371361A-01/glang/tools_palette_icons/
Message 4 of 9
(11,885 Views)
Thank you very much, I got it. There was a simple step that I was missing. I am using version 8.
Chris
Chris Reyerson
Arete Associates
Tucson, AZ
Message 5 of 9
(11,879 Views)
Hi all,
just a comment to the color pane of the coloring-tool. You can select the foreground color by pressing "F", background color by pressing "B" and all of them by pressing "A". I find this more useful than toggling with <space>.
Greets, dave
Greets, Dave
Message 6 of 9
(11,872 Views)
hi chris how can i do this? i am using LV 2011
Message 7 of 9
(10,940 Views)
Start with a Simple numeric or Simple string indicator in the Classic controls palette.
Select both FG and BG colors as Transparent and then color the indicator.
Paolo
Message 8 of 9
(10,929 Views)
