Display the last data in the table control in the first row when I scroll down to the end.
I am trying to make my table control to display the last data in the first row of the table control when I scroll down to the end. Is there any method to do this? I just want the last data to display in the first row of the table control when I scroll down not to the first row of my array. Please suggest some method to do this.
(3,498 Views)
Sounds like you are looking for the Index Values property of the table.  With that property you can get/set which item is in the top left corner of the display.
GCentral
(3,469 Views)
I also feel that I have to use this property but I don't know how to use on this property. I have try to create a indicator to see what value will it give up when I am clicking on the table control but it didn't give out any value. Can you give me some guide?
(3,417 Views)
I do not understand what you are trying to say.  Clicking on the table changes the Active Cell.  That is a different property.  The Index Values just tells you which cell is in the top left corner.
GCentral
(3,387 Views)
