12-13-2022 07:09 AM
Hello
I am currently saving data from a labview application into a text file. It contains multiple columns and rows. the 1st column is time and date data in the format the client prefers, subsequent columns displays temperature data. I would like to be able to display this data on a graph with the 1st column(time and date) being on the x Axis and then subsequent columns showing the temperature data.
The temperature data is straight forward to handle but I am struggling to get the correct format on the time date column for the X axis.
I understand maybe a solution is to initially save the date.time in different format, but i would prefer to work with the file contents as it is now.
Many thanks in advance.
I have attached a sample file
Solved! Go to Solution.
12-13-2022 07:27 AM - edited 12-13-2022 07:28 AM
Hi Lee,
Try ScanFromString with %<%d/%m/%Y %H:%M>T to scan the timestamp...
(I guess it is day first, month 2nd because of the "Winter" mode - and the 24h mode. 🙂)
12-13-2022 08:14 AM
Hello
Yes, scan from string - works a treat 🙂 Once I worked out format for input, in my case ending up being %<%d/%m/%Y %H:%M>T
I have attached my interim solution, ready to build into my applicaiton
Thank you
12-13-2022 08:26 AM - edited 12-13-2022 08:33 AM
@GerdW wrote:
Hi Lee,
Thusly
The display is m/d/Y but that does not change the DATA of output 1 (Timestamps are stored internally as UTC) Its that "%<>T" that clues LabVIEW to use an Absolute Time container
