Displaying Two Signals on a Strip Chart
Everyone,
Strip charts have always been my downfall.  Please see the image "Single Data Point Works" to see a block diagram of a program that neatly plots a series of points on a strip chart.
I thought it would be simple to add another data series to plot on the same Y axis.  I just added another data point to each array I feed into the "Y" terminal of the "Build Waveform" block.  When I do that, nothing works.
Any help would be greatly appreciated.
Thanks!
Forbes Black
Lapsed CLAD, LV 5 - LV 2023 (Yeah, I'm that old...)
(4,250 Views)
Open up the example finder and find the charts.vi. LabVIEW>>Help>>Find Examples.
Or just copy the code you had inside the while loop of your first vi with the exception of having 2 charts. Out of the 2 build waveform primitives add a build array primitive and wire that to your chart.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,220 Views)
Accepted by diarmaede
See if this is what you are looking for..
CLD
(4,217 Views)
Sorry it took so long to get back to you, but YES, that was what I was looking for.  Thanks!
Forbes Black
(4,114 Views)
