Displaying the waveform the multimeter (34401)
I encounter some problems in diplaying the using the waveform graph. It seems that I can't connect the data directly to the waveform graph.
The error shows that the problem is unable to connect two different type of terminals, the source is string & the sink is 1D array. Please advise on how I can display the readings in a graphical form.
(3,079 Views)
You were pretty close, except you need to have the input to your indicator come from the String-to-Number function.
I think you need a chart instead of a graph, but if you need a graph you can insert a Build Array or Convert to Dynamic Data into the wire, depending on the nature of your data.
</jim>
Message Edited by jcarmody on 01-15-2009 06:15 AM
Message Edited by jcarmody on 01-15-2009 06:17 AM
Jim
(3,061 Views)
Accepted by Syawalt
Thanks a lot for taking you time solving this little issue. Thank you and get well.
(3,041 Views)
Hai Syawalt,
Could you please mark jcarmody's post as solution, that will help others who are looking for a solution for same kinda problems.
(3,035 Views)
