Displaying values on the intensity graph directly - MLX90621
Hello All,
I am trying to plot the temperature values directly on the intensity graph instead of having a separate array as shown.
Is there an option or a way to do this ? Please Advise
Atif
Message 1 of 8
(4,383 Views)
Hi Aaatif,
You already do so:
So what's the problem?
Where do you have a "separate" array?
Message 2 of 8
(4,373 Views)
Hi
Message 3 of 8
(4,363 Views)
Hi Aaatif,
several options:
- make the numeric array transparent (both the element and the array container). Then put it in front of your intensity graph to have the numbers in front of the colors
- fake the intensity graph by using colorboxes: use the same approach as before and put a numeric indicator in front of a colorbox (one per array element)
- draw the numbers into a 2D picture, then use that image as "front image" of the intensity graph (see it's property nodes!)
- use annotations of the graph to "draw" the numbers at the right position
Message 4 of 8
(4,353 Views)
Thank you on your advise and patience to type so many options for me, would try one of these and keep you updated if i succeeded.
Best Regards,
Atif.
Message 5 of 8
(4,333 Views)
Hi GerdW,
Using this - - make the numeric array transparent (both the element and the array container). Then put it in front of your intensity graph to have the numbers in front of the colors.
I got the concept of making the 2D array transparent, How does on put (overlay) it in front of the intensity graph?
Attached is what i tried .vi
Atif
Message 6 of 8
(4,327 Views)
Accepted by topic author Aaatif
Hi Aaatif,
You only made the array element transparent, but not the array container itself.
Did this for you…
You set the numeric array to front, then you move it over the intensity graph…
See attachment.
Message 7 of 8
(4,320 Views)
Hi
Thank you so much .. that did it ..
Will attach the final .vi below it could help some one out too.
Best Regards
Aatif
Message 8 of 8
(4,317 Views)
