Distribution of executables
What is the best way to legally distribute applications/executables to other PC's without purchasing full base packages for each PC? Small company, about 5 test stations. Application builder? Run-Time Engine? I am using 5.1.1. Thanks, Alan
(3,155 Views)
You need to buy the application builder which will require the installation of the free run-time engine and the built executable on each pc. Certain LabVIEW add-ons also have additional license requirements. Your release notes should have details on them.
(3,155 Views)
Application builder.
One time testing of your application. Think of the hours you've got to spend
on programming the same another way. If it works on your station, it will
work on the others. (they should be somewhat the same of course... same
drivers, same hardware (DAQ-cards etc.).
I also bought the application builder and am very happy with it.
'small company, about 4 test stations.....'
Ron@ld
AlanSpectrumControls schreef in berichtnieuws
506500000008000000C7980000-1042324653000@exchange.ni.com...
(3,155 Views)
