How do I turn on and off the RTS on a Fireberd 6000 using the driver libraries?
I have a fireberd 6000 connected to a PC via a GPIB connection and I want to be able to turn on and off the RTS. I have downloaded the driver libraries for the fireberd, but there is no documentation explaining how to go about using them. Is there some help files somewhere that would explain how to accomplish this?
(2,966 Views)
It's been many moons since I've used a Fireberd, since I'm no longer with the phone company, but if memory serves, that can be turned of directly with a fireberd command. You might check the manual for that. If so, then all you need is a simple "send GPIB" command from Labview
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,966 Views)
The VI you want to use is FB 6000- CNFG- RS-232 & RS-499 signaling leads.vi. The only documentation is included in the VI itself and is visible as you browse through the functions on the palette if you have Show Context Help turned on.
(2,966 Views)
