Divide and Plot a String Output
Hello Everybody,
my LabView programe is receiving Values from 4 Channels of a DAQ-Unit.
However, the next step is to divide the String (which contains these four values) and show them into a seperate display.
Furthermore, i would like to plot these values in a seperate graph.
Could someone explain to me, how i can realize it?
Cheers and thank you in advice,
Marc
P.S.: the .vi is in the attachmentLabViewTasks.png
Message 1 of 11
(6,170 Views)
It's possible to get more informations about the format of received data. May you share a picture of the result in read buffer indicator.
Best regards.
Message 2 of 11
(6,144 Views)
It's something like that.
Every second the DAQ-Unit measured a value on every channel.
So i want to split the 4 Values into seperate displays and plot every value in a seperate graph (value vs time).
Message 3 of 11
(6,138 Views)
What's the model number of your instrument. Did you do a search for an existing driver? Your code is poorly written with the constant opening and closing of the VISA session and the file I/O. The parsing of the string is trivial and you would benefit from some of the free LabVIEW tutorials.
Message 4 of 11
(6,125 Views)
Hello MarcTUD,
a simple way
Hope it helps
best regards
Alexander
Message 5 of 11
(6,086 Views)
Thanks for your reply, it helps a lot!
Next, i need to transform the values from the array 1 into numerics (decimal numbers) and need to plot each course into four wave forms.
Could you explain how i could do that?
Cheers,
Marc
Message 6 of 11
(6,072 Views)
Hello Marc,
you can use the arry to cluster function and then put the values out to a chart.
Attached the VI.
best regards
Alexander
Message 7 of 11
(6,058 Views)
I inserted your solution into my programe (works fine by the way).
What I mean is, that I have now an array with 4 lines (numerics) - and for each line, I would like to create a graph waveform (value vs. time).
Do you know what I mean?
Message 8 of 11
(6,048 Views)
Have you made an effort to write this code or you expecting to be given VIs for your entire project ?
Message 9 of 11
(6,037 Views)
Accepted by MarcTUD
Hello Marc
attached an example
best regards
Alexander
Message 10 of 11
(6,025 Views)
