Dll call in LV (usbm.dll)
Hello all,
I'm having a hard time figuring out how to call a DLL in Labview. I've read a little bit about it but am still a newbie. The DLL in question is usbm.dll (http://www.usbmicro.com/, the list of functions & types is documented there). I use the call library node to call the DLL.
As long as I call functions with no input argument things work fine (for instance my first 2 calls check for device presence and number of devices, and work ok returning the proper output)
Then I try using functions with arguments (3rd step in the VI) and Labview doesn't take them (Error 1097). I'm going for function "int USBm_DeviceValid( unsigned char device )" , I believe the argument should be of type uint8 and output of type int8... I've tried all numeric types to no avail.
On top of that, if I skip step 3 of the VI and go to step 4 (calling a function which takes 2 parameters and sends a command to my device) : the function is executed (eg the device moves), but then Labview crashes (exits with no error message). Is this due to improperly calling the function ?
Any suggestions would be welcome, thanks !
(3,418 Views)
What version of LV are you using? I have 2010 and can't even open the VI...LV crashes without any message?!
CLD
(3,415 Views)
LV 10.0 32bit , under XP64. Yes, it closes with no message.
(3,412 Views)
Wow that is what I am using. This seems to be an interesting issue. Did you try with any other DLL? maybe Windows DLL jst to test?
CLD
(3,392 Views)
Accepted by topic author degemer
Hi lvrat, thanks for your suggestions.
I got around the problem. I recovered an older version of this usbm DLL (together with some LV example files) which works fine. Looks like the more recent DLL I was using has some issue with Labview...
I'm attaching these files (they were not easy to find), in case someone else tries to interface to an USBmicro device.
(3,383 Views)
