MISSING DCFGPORT.vi and TInScan.vi SUBVIs
I have recently installed labview 8.2.1 on my new computer after the previous one crashed. I was able to transfer all of its previous labview data into the new one. My problem is that when I run one of the VIs I get, labview tells me that I am missing the following subVIs: DCFGPORT.vi and TInScan.vi. I have searched for these two thoroughly on my new computer but can't seem to locate them. Is there a reason why? Can I find these subVIs on the internet, If so, how?
(3,036 Views)
Hey H.K.K,
Those VIs you are referring to are not a part of the standard LabVIEW installation. They appear to be a part of the Universal Library for LabVIEW. This library is part of your DAQ drivers. In order to get these VIs back, you will need to install (or reinstall as the case may be) your DAQ drivers. Here is a link to a download site for the drivers, in case you are not able to find your installation media. Hope that helps!
John B.
Embedded Networks R&D
Certified LabVIEW Developer
(3,015 Views)
