Do I need to reinstall the VI analyzer after installing 8.6.1
(3,304 Views)
Are you experiencing problems with VI Analyser since installing LV 8.6.1? Or just asking?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,300 Views)
I assume you had LabVIEW 8.6 installed along with VI Analyzer 1.1.1.  You then installed LabVIEW 8.6.1.  Is that correct?  Assuming it is, then you should have no problem with the VI Analyzer...it shouldn't require a reinstall.  That being said, if you're having problems, let me know, along with answers to the following questions:
1.  Are you on Windows?  If so, is VI Analyzer 1.1.1 listed in Add/Remove Programs under NI Software?  If not, it somehow got uninstalled, and you need to reinstall it.
2.  If it is installed, does the VI Analyzer 1.1.1 appear as an activated toolkit under LabVIEW 8.6.1 in the NI License Manager?  Does LabVIEW 8.6.1 appear as activated?
Next time you have a question, posting as much information as possible will help you get answers faster.
Message Edited by Darren on 06-04-2009 09:26 PM
(3,291 Views)
I was using LabVIEW Ver 8.5 on Linux. When I loaded 8.6.1 the analyzer is no longer available. As far as I can tell there is no activation on Linux. When I look at the read me on the Analyzer CD there is no mention of ver 8.6. Can I reinstall or do I need to get an updated version of the analyzer.
(3,274 Views)
When you install a LabVIEW upgrade (i.e. going from 8.5 to 8.6.x), you need to reinstall the VI Analyzer as well.  For VI Analyzer 1.1.1 for Linux, the product was shipped as a .tar file on the CD (not an installer), so all you need to do is un-tar the VI Analyzer files to the new LabVIEW 8.6.1 install location on your Linux machine and you should be ready to go.  Note that there is no difference between the VI Analyzer 1.1.1 on Linux for LabVIEW versions 8.5 and 8.6.
For your reference, the VI Analyzer for Linux is located on your VI Analyzer CD in the following location:  [CD]\LabVIEW_8.0-8.5\Linux\VIAnalyzer1_1Linux.tar.  Let me know if you have any additional questions.
(3,272 Views)
Thanks Darren! That solves my problem.
(3,265 Views)
