Do IMAQ Cast Image or IMAQ Linear averages give different results when using different computers that are running under Windows XP ?
Hello
I'm currently developping an image processing algorithm using Labview 7.1 and the associated IMAQ Vision tools. After several tests, I found a weird result. Indeed, I put the labview algorithm - including the IMAQ VI on the library to get sure that I use all the time the same VI - on my memory stick and used it on two different computers. I tested the same picture (still in my memory stick) and had two very different results.
After several hours trying to understand why, I found that there were a difference between the results given by both computers at the very begining of the algorithm. Indeed, I used a JPEG file.
To open it, I first create an Image with IMAQ Create (U8). Then, I open it.
Then in my first sub-VI, I use IMAQ Cast Image to be sure that the picture is a U8 grayscale picture.
Right after that, I use the IMAQ Linear Averages. The results of this VI are different on the two computers.
I tried several time on the same picture : one computer always give me the same result but the two computers give me a different result. So there is no random variable on the results.
So my question is : Do IMAQ Cast Image or IMAQ Linear averages give different results when using different computers that are running under Windows XP ?
My bet is on IMAQ Cast Image but I'm not quite sure and I do not undestand why. The labview and IMAQ are the same on both computers.
The difference between the two computer are above :
Computer 1 :
Pentium(R) 4 CPU 3.20GHz with a RAM of 1Go. The processor is an Intel(R).
The OS is windows XP Pro 2002
Computer 2 :
Pentium(R) 4 CPU 2.80GHz with a RAM of 512Mo. The processor is an Intel(R).
The OS is windows XP Pro 2002.
If anybody can help me on this problem, it would be really helpful.
Regards
Florence P.
(2,378 Views)
Indeed it's a strange behaviour, could you send me your VI and your JPEG file, (or another file that reproduces) so that I could check this inthere ?
I'll then try to find out what's happening.
Regards
Richard Keromen
(2,358 Views)
