Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Do event sequences need to be called to inherit global values?
lfoitek
Member
09-07-2006
09:29 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
hello,
if i have an event sequence that produces data, do you need to call the other events to get the data to inherit in them. or is there a way to not call the other events and have the data inherit to them? thank you
0
Kudos
Message
1
of 2
(2,581 Views)
Reply
Re: Do event sequences need to be called to inherit global values?
altenbach
Knight of NI
09-07-2006
08:53 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I am not quite sure what you mean by "inherit". Can you attach a simple example?
If the data needs to be accessible in the other cases and retained if other cases execute, you should place the data in a shift register.
LabVIEW Champion
0
Kudos
Message
2
of 2
(2,567 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
