Do event sequences need to be called to inherit global values?
hello,
if i have an event sequence that produces data, do you need to call the other events to get the data to inherit in them. or is there a way to not call the other events and have the data inherit to them?  thank you
(2,575 Views)
I am not quite sure what you mean by "inherit". Can you attach a simple example?
If the data needs to be accessible in the other cases and retained if other cases execute, you should place the data in a shift register.
(2,561 Views)
