‎06-29-2005 05:27 PM
‎06-30-2005 01:30 PM
‎06-30-2005 01:45 PM
‎07-01-2005 12:31 PM
‎07-05-2005 01:10 PM
‎07-06-2005 01:10 PM
‎07-06-2005 06:55 PM
Hello Grad Student!
There is no arbitration nessessary this is all taken care of in the translation from LabVIEW to the FPGA. Have a great day!
Allan S.
‎07-06-2005 07:05 PM
Hello Grad Student!
That number you are asking about is a maximum speed in which your code could actually be run at. This number is determined by what is actually going on inside your code at compile time. I am unaware of the algorithm that actually determines it. The single cycle loop will execute one iteration in the time of one cycle of the setting of your clock (which is the other number not the maximum number). Therefore the role of the maximum number in the execution of the single cycle loop is stating the fastest clock rate you could run your single cycle loop at. Let me know if there is anything I can be more clear about. Have a great day!
Allan S.
