Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Do the inport pins 10 - 13 have internal pull up resistors?
leicester
Member
03-10-2005
03:57 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
IEEE 1284 25 pins parallel port......Do all the inport pins 10 - 13 have internal pull up resistors?
0
Kudos
Message
1
of 2
(2,489 Views)
Reply
Re: Do the inport pins 10 - 13 have internal pull up resistors?
Dennis_Knutson
Knight of NI
03-10-2005
02:22 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I don't know for sure but I suspect that it would depend on the manufacturer and type of the transceiver IC used. I don't have access to the IEEE spec. If you do, what does it say about required terminations?
0
Kudos
Message
2
of 2
(2,477 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
