Do you have Ethernet Drivers /OPC Server on Linux?
I plan to use LabView as HMI and Control engine on PC with Linux OS, talking to AB IO via Ethernet. You have OPC server for Windows. Is there any for Linux?
(4,012 Views)
Greetings,
Currently there is not an OPC server software package for the Linux environment. As an alternative, you could utilize the NI IA OPC Server on a windows machine and then access the Server through a network. Whenever this is done from two Windows PC's, the only factor is setting up Microsoft's DCOM properly to allow the remote connection. There appears to be something very similar to configure on a Linux machine as well. Take a look at this document for more information.
http://www.technosoftware.com/opcsolutions/documents/OPCLinux.pdf
Hope this helps. Good luck with your application!
Patrick R.
(4,012 Views)
