Do you have a VI that create a step analog output voltage (for example: a voltage that increases of .1 V from -10V to 10V)
Try the attached VI. I think it will do what you want. It's setup to used as a subvi. Check context help for more information on how to use it.
This is saved in 6.0.2, but upgrades with no problems and should be platform independent.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,742 Views)
Pretty simple to create with the Step Function.
(2,742 Views)
Meant to say Ramp Pattern function.
(2,742 Views)
