Do you know how to create Front Panel like Web,
Do you know how to create Front Panel like Web, I mean like we pointed the word and click it will do another process instead by clicking push button.
If possible, i can click the link in the table... Any idea anyone 🙂
(5,670 Views)
Not too sure if I have understood this one fully as pointing at a word doesn't mean too much.
You can load a picture in Labview then launch other vi's dependent upon where the mouse is clicked/ moved to, see http://forums.ni.com/t5/LabVIEW/map-display-as-switches/td-p/828974?query.id=320052 for some ideas on working out where the mouse is relative to a picture - Mike
(5,659 Views)
Accepted by ezam
I believe the user is asking about a hyperlink control. See, for example: http://forums.ni.com/t5/LabVIEW/NI-Example-Finder-Like/m-p/1023011#M455994
You could probably make this into an XControl.
(5,654 Views)
Hi ezam,
can you define more clearly exactly what you would actually like to do, and ill have a further look into it. I think
any way, give a shout back with exactly what you want to do and we see what we can do,
Richard
Richard S
Applications Engineer
Certified LabVIEW Associate Developer
National Instruments UK&Ireland
(5,624 Views)
@RLSSpeedy wrote:
Hi ezam,
 I think
Richard
Acutally, I said XControl, not ActiveX. Two different beasts. One is LabVIEW-native, the other is Windows-only. Smiley Wink
(5,614 Views)
Hi ezam,
Do you mean this ?...
http://zone.ni.com/devzone/cda/epd/p/id/3741
(5,585 Views)
thankx got the solution
(5,334 Views)
