Documenation error for DAQmx Timing and samples per channel?
The documentation for DAQmx Timing says the samples per channel input should be an unsigned long integer.  All instances of the actual Timing VI seem to want a signed long integer, instead. Won't this cause problems when setting more than 2,147,483,647 samples? It probably doesn't come up too often, but some of the M-series boards have 32-bit counters, where it could be relevant.
Wiring a U32 to the Timing VI with a large number, say 3E9, causes the sample per channel input to be coerced to an I32, making it a negative number. The Timing VI then throws an error.
The Timing VI just seems to be a convenient interface to a Timing property node, which sets SampQuant.SampPerChan.  One can get around this by setting the property node manually with a U32 (which gets coerced to a DBL, but that doesn't affect anything).
This is under DAQmx 8.0.1, and Labview 7.1.1.
(2,613 Views)
Hello eaolson,
Thank you for finding that.  In DAQmx 8.1 the C reference help indicates it should be a uInt64, and LabVIEW seems to cast it to an I32.  I will let R & D know about this.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
(2,601 Views)
