NIHypertrend ActiveX programmable Active Group Select
Before I used Hypertend Object alone for data plot but right now with higher customer demands on more features I decided to switch to NIhypertend ActiveX control.
What I haven't found in the object connections, there is no programmable option to select an active Group, other than when User manualy right mouse clicks at the NIHypertrend object itself.
For example If I want to display graph with one Y axis which is the Temperature, user may select either Celsius or Farenheit just by clicking at the Switch object.
Switch Object should change the active group and display either Celsius or Farenheit scale and after the process is done report is beeing crated for the selected Group.
Other thing I'dont know is it some known issue, if I delete the NIhypertrend from the display only and try after to insert it as an Object, Lookout encounters an Error and terminates.
Message 1 of 1
(2,557 Views)
