Documentation on PostLVUserEvent() function
We are developing an application where we have some C code in a .dll that has callbacks in the functions.  We have seen examples of code that uses the PostLVUserEvent() function along with other functions that do memory allocation, DSNewHandle().  Is there any more recent documentation on these functions (all I have is something dated April 2003 called Using External Code in LabVIEW)?  Also, does the code in the .dll have to manage the memory?  Does it have to deallocate the memory created with the DSNewHandle() function between each call, or would one normally allocate the space at the beginning of the program and then deallocate it with the DSDisposeHandle()?
Bob
(5,003 Views)
Accepted by BobDescham
Hi BobDescham,
It took some digging, but I found a bit more documentation for the two functions that you’d mentioned. I found this article- http://digital.ni.com/public.nsf/allkb/89165EDE5031C68686257B2E0006FE99- which discusses using callbacks in C, specifically mentions PostLVUserEvent(), and talks some about how it’s used. There’s also the help page for the function: http://zone.ni.com/reference/en-XX/help/371361M-01/lvexcode/postlvuserevent/.
DSNewHandle() is used to allocate memory, here’s its help page: http://zone.ni.com/reference/en-XX/help/371361M-01/lvexcode/aznewhandle_dsnewhandle/, and here’s a more in-depth article that talks about memory handling, and the functions involved: http://zone.ni.com/reference/en-XX/help/371361M-01/lvexcodeconcepts/memory_manager/.
Kathryn K.
Applications Engineer
http://ni.com/support
Kathryn K.
Technical Support Engineer
(4,959 Views)
