Does Application developed Using LabVIEW requires License to distribute it to other users
This application basically Modbus Device simulator it can run on any PC how i can confirm it requires license to execute on other user machine or can i distribute it freely to any user
guide me on this ?
(1,937 Views)
Accepted by rupeshM
You can create an installer in the Licensed version and distribute/Deploy to as many as possible if you are not using any toolkits which requires RTE License.
(1,918 Views)
Accepted by rupeshM
All of your source code and compiled executables are your (or your company's) intellectual property.
You are free to distribute your source code and executables as you see fit.
You can even charge for them as long as you are:
  1. Not using the LabVIEW Community Edition
  2. Not charging for the required LabVIEW Runtime libraries
  3. Not distributing the LabVIEW development package, separately purchased add-ons, or toolkits
Some NI and third party toolkits may have other licensing and distribution restrictions
=== Engineer Ambiguously ===
(1,867 Views)
I think technically you have to put in a little readme regarding LV, but I can't remember what that is.
Bill
CLD
(Mid-Level minion.)
(1,850 Views)
