Does LabVIEW C Generator generates multi-dimensional code or only vectors
What is the C generated code for a LabVIEW VI/block diagram using matrices?
This:
matrixVar[row][column] = value;
Or this?
matrixVar[row*Ncolumns + column] = value;
Ivan
(5,044 Views)
LabVIEW (Plain, RT, etc.) does not generate C code. It processes the diagram into machine code (via DFIR and LLVM).
(Details)
(... or are you talking about this rare beast for embedded targets?)
(5,032 Views)
Yes, I am referring to that rare beast for embedded targets (why called rare beast?).
https://www.ni.com/en/support/downloads/software-products/download.labview-c-generator-module.html
(5,017 Views)
Thanks, I noticed your other thread.
I called it "rare" because I almost never see it mentioned here. Maybe there is a more suitable forum (embedded, etc. ??), hard to tell for me. 😄
(5,014 Views)
This:
Or this?
Ivan
(4,961 Views)
Posted this question on that Labview Embedded threat. Thanks!
(5,009 Views)
Accepted by LVCCGUser
LabVIEW multidimensional arrays are an array with the multiplication of all dimension sizes elements, not an array of pointers! It is also what most C libraries use because it is more standard and easier to handle.
Matrixes being in principle simply 2-dimensional arrays make no difference!
Rolf Kalbermatter  My Blog
(5,002 Views)
