Does LabVIEW have an automatic API document generator?
Java has javadoc which automatically generates API documents.
Does LabVIEW have an equivalent or a similar thing to this?
(3,712 Views)
--deleted---
sorry wrong post.
Thanks as kudos only:)
(3,708 Views)
It does! Check out your File->Print... menu from a VI panel. You can select multiple VIs to be documented. It will create HTML or other type documentation (depending on your platform) of all the VIs you added to that dialog.
I would agree that this is sort of hidden and more correctly would belong to the Tools menu or the Help menu as some sort of VI Documentation Generator, but it's not a high frequently used tool, so I'm more than happy it exists and I never bothered to suggest a change.
Rolf Kalbermatter  My Blog
(3,686 Views)
It probably is infrequently used because it is somewhat hidden. If you come up with something and post it on the idea exchange, I will give it kudos.
LabVIEW 2012
(3,667 Views)
Accepted by iCat
The File Print function can be called programatically as well.  Pass a VI reference into a Invoke node and select the Print >> VI to HTML function to generate HTML documentation for the VI.
(3,662 Views)
