Does LabVIEW webservice allow us to use cluster as input
I want to know whether the LabVIEW Web Service allow us to use Cluster as one of the Input for the web service.
For e.g., Cluster consists of two numbers A and B. I just want to sum the numbers and provide the output to the user.
I want to give the values for the Numbers A and B which is present in the Cluster.
Here i want to know whether Cluster format is allowed. If so, then please provide me the URL Mapping for the above example.
Alagar
(2,724 Views)
Hi
you can get some details here
(2,716 Views)
Hi GK,
I have tried using Cluster as Input and i am not getting expected output instead it always gives out zero as the result.
Also, i couldnt infer anything related to cluster from the document.
Alagar
(2,707 Views)
